-   Tires and Wheels (https://blazerforum.com/forum/tires-wheels-13/)
-   -   Bolt Pattern? (https://blazerforum.com/forum/tires-wheels-13/bolt-pattern-62303/)
spdfrk_29 Aug 20, 2011 01:08 AM
Bolt Pattern?
I googled and it says 5x120.7 or 4.75inches . Then when i measure i get 114mm or 4.5 inches ???? Am i doing something wrong ???
And yes i can read a tape measure lol
DySfUnCtIoNaL Aug 20, 2011 04:42 AM
Must be doing something wrong cause Google is right.
How To Measure A Wheel Bolt Pattern
spdfrk_29 Aug 20, 2011 01:33 PM
Ok so if I am doing something wrong and google is right. When you messure where do you messure from ? from what point to what point ??? Anybody know ?
spdfrk_29 Aug 20, 2011 02:35 PM
Ok So I got my buddy across town to pull of a rim and measure . He told me 4.5 inches and he measured his burban and it's 4.75. When I googled it said s10 Blazer 5x120.7 or 4.75. I dont get it.
I have always measure center to center is that wrong?
Rottidog Aug 20, 2011 07:44 PM
Maybe a previous owner put on a lug pattern spacer so they could fit rims that are 5 x 4.5 & not the stock 5 x 4.75?!
I'm not completely sure how they look & what other side effects might be so google would be your friend for research.
LS Twins Aug 20, 2011 08:15 PM
Measure the lug pattern from the center of the studs, skipping one of course
spdfrk_29 Aug 20, 2011 08:36 PM
Ya thats what I did center of stud skip one and center to another >4.5inches or 114 mm. If I measure it any more times im gona go crazy > so my blazer is 5x114 and so is my buddy's since I drove to his place to make sure.
Thanks guys
AJBert Aug 20, 2011 11:50 PM
You do NOT measure from center of stud to center of stud. Take a look at the google link again. You measure from center of stud to outside of stud. This is why your are coming up with 4.5".
spdfrk_29 Aug 21, 2011 02:04 AM
Thanks Albert
That would makes sense and would get 4.75. So why is that different from 4 bolt patten, cause 4 bolt u measure center to center.
Why does 5 bolt have to be different.
AJBert Aug 21, 2011 06:25 PM
Not a clue as to why, just something you need to know if you ever look at a set of rims or rotors.
