Bolt pattern???
Old Oct 21, 2011 | 01:51 PM
ComputerNerdBD's Avatar
ComputerNerdBD is on a distinguished road
Default Bolt pattern???
Hey everyone. I am looking at snow tires and wheels on Craigslist. Which bolt pattern fits these trucks? I saw one that was "5 x 4.5" off a Jeep. Will that fit? Thanks
Edit: Will 225/75R15 fit without an issue? I have 235/75R15 on there now and I have used 215/75R15 and 235/70R15 in the past. Tire experts willing to give their professional opinion?
Old Oct 21, 2011 | 01:52 PM
chris015's Avatar
Bolt Patt.- 5 lug x 4.75"
Back Spacing- 4wd: 6" 2wd: 4"
google search for the win...
Old Oct 21, 2011 | 02:26 PM
TripleBlackBlazer's Avatar
OP is 4wd but 2wd BS is 4".
Also: Tire size calculator
225/75/15 will be roughly half an inch shorter and 0.393700787 inches narrower than what you have on there now.
What was your truck originally equipped with? If it's different than what you're running now, your speedometer will be slightly off. The website I linked allows you to plug in stock size vs. what you have to tell you the difference between the two.
Old Oct 21, 2011 | 02:47 PM
That difference seems like nothing since these current tires seem oversized as is. Does half an inch make a difference in terms of traction, handling, performance, etc?
The truck was originally equipped with 235/70R15 according to the door label.
I realize the speedometer is slightly off already by about 1-2mph according to the GPS. Not much at all.
I will check out the comparrison site. Thanks for the tip.
clutch
Tires and Wheels
17
Feb 3, 2007 04:29 AM
4x4blazin
Tires and Wheels
Dec 14, 2006 10:53 PM
sledneck16
Sep 19, 2006 08:43 PM
dubluj
Dec 12, 2005 02:09 PM
Grkblazer
Tires and Wheels
Sep 4, 2005 02:54 PM
