Buying new rims for '97 ZR2
Old Mar 23, 2009 | 03:40 PM
ZoeR2Girl's Avatar
ZoeR2Girl is on a distinguished road
Exclamation Buying new rims for '97 ZR2
I'm looking in getting a set of four Daytona "D's" for my 1997 Chevy ZR2 Blazer. I need a 15x8" rim with a 5x4 1/2" bolt pattern. Does anyone know if I should worry about backspacing inches or offset milimeters?! Please HELP!!
Old Mar 23, 2009 | 07:05 PM
football8686's Avatar
football8686 is an unknown quantity at this point
If I were you I'd get rims with 5x4.75 bolt pattern
Old Mar 24, 2009 | 12:05 AM
AJBert's Avatar
Get the backspacing as close to stock as possible. Stock backspacing is 6" if you didn't know.
Old Mar 25, 2009 | 11:07 AM
DJ 4x4's Avatar
DJ 4x4 is an unknown quantity at this point
Like stated your bolt pattern should be 5 on 4.75. And on backspacing you will want to stay close to 6. If your wanting to get a 15x8 rim then you will really want to stay close to 6 because thats a 1 inch wider rim already so ur tires are going to stick out 1 inch more and if you get like a 4 inch backspacing rim ur tires will be out 3 inchs. Thats alot if you dont have any lift then you will most likely rub on the flares when turning. Hope that helps.
Old Mar 25, 2009 | 01:19 PM
bandidolenny's Avatar
Finding 15x8s with with a negative offset can be a real challenge. I ordered mine through Discount Tire Co. but there are others. You might also try Summit Racing if you are set on aluminum.
Keystoneguy91
Tires and Wheels
Oct 27, 2012 09:40 PM
brendan127
Tires and Wheels
21
Nov 21, 2011 01:17 PM
Logan
Jun 4, 2009 08:51 PM
Mule
Apr 12, 2007 03:53 PM
BlueBlazzin
Tires and Wheels
Jan 14, 2006 08:48 PM
