Caliper rubbing on rims
Hey guys, I recently got some Cragar Soft 8's with -4 inches of backspacing and they rub on the calipers just a little bit on the front.
I know the only solution is just getting spacers and I will when I can afford them, but I am just curious if anyone else has had this problem.
When reading about other people's Cragar's, I never saw this come up, could it be because the -4" of backspacing?
Also, the offset on them is -12mm. Could this have an effect on the caliper rubbing?
Thanks.
Thanks.
i just put on my soft 8's today and had the same issue. i just ground down the bracket a little and it seems fine. im always paranoid when it comes to these things. mine only rubbed a little bit on left turns. grinding seems to have fixed it.
is it rubbing the caliper or the bracket? My pro comps rub on the bracket. I just ignored it. I found the steel wheel is stronger than the cast bracket. All it did was wear the paint of the wheel but it ground down the caliper brcket
