Camaro Rims
Finally did it.... Got the Iroc/Z28 style wheels for my truck.
https://cimg8.ibsrv.net/gimg/blazerf...cd5d39b2e.jpeg After some fresh paint, and some rear spacers, these will look pretty nice. I will probably put the Kumho rubber on these... But I do have some General Grabber ATs laying around. Also, thinking about fabbing some center caps from a 2nd Gen 2wd s10 pickup onto these...with the help of a dremel. :icon_naughty: |
Please post pics if you do this. I would very much like to see the results. 👍
I really like the look of these Camaro SS wheels, I believe from the 98-02's. I may put these on my 01 ZR2 Blazer.
https://cimg5.ibsrv.net/gimg/blazerf...848e6e5907.jpg98-02 Camaro SS wheels on a ZR2 |
Be sure to post up some pics! I'd like to see the modified center cap setup.
I had Firebird wheels on mine for a little while and liked how stock they looked. Like an option that GM should have offered but never did on the 4x4 S-chassis. http://i113.photobucket.com/albums/n...007_191004.jpg |
I went with the older style rims cause I have some stock 15"s with good tires I will swap on ... Otherwise I would have went with the 16"s.
I found a set of center caps on ebay that look stock...but I like the custom look. I'll hit the boneyard this weekend and see if I can find the caps I have in mind... 2 wheel drive s10 caps. |
(Post 691455)
I found a set of center caps on ebay that look stock...but I like the custom look. I'll hit the boneyard this weekend and see if I can find the caps I have in mind... 2 wheel drive s10 caps. Will be nice to see those Z28 rims on your Blazer, good luck with the center caps. Here's another pic of the Camaro SS wheels, I believe they're 17". https://cimg5.ibsrv.net/gimg/blazerf...f2a45f9bc1.jpg |
Originally Posted by Zenith
(Post 691459)
Been a minute..
Decided to save my immediate dough and plasti dip them.
https://cimg4.ibsrv.net/gimg/blazerf...c1e048071.jpeg https://cimg9.ibsrv.net/gimg/blazerf...58761a6955.jpg https://cimg5.ibsrv.net/gimg/blazerf...b57686db4.jpeg Turned out pretty decent for my first Plastidipping experience. Picked up these center caps off ebay. We'll see how long they will last, either before I get sick of them or they fall off. Looking at getting some ZQ8 centers to run on them... Anywho, I will be getting them on this weekend, hopefully with my rear spacers and an alignment to boot! |
Could black out and throw some ZQ8 center caps on them
see here https://www.thirdgen.org/forums/susp...er-center.html |
(Post 692492)
see here https://www.thirdgen.org/forums/susp...er-center.html I will def be checking it out. |
I put a couple of screws through the back of the rim to hold my caps into place, they are the original ones so there is alot of play in them. I'll try to post pics later after work.
Thanks DonL. I have seen a few similar setups...would like to see how you've got them screwed on.
I didn't have a screw driver with me, so I wasn't able to take any pictures of them separated. But I got a few pics to give you an idea of them...https://cimg7.ibsrv.net/gimg/blazerf...7e1bd17d54.jpg
https://cimg1.ibsrv.net/gimg/blazerf...57157aab3c.jpgNot sure if they came stock with the three holes, but it looks like it. 5 holes in the cap to screw into. |
Whoa, that's very handy. Thanks for sharing. The screws would definitely be a good peace of mind to have, and a decent theft deterrent.
https://cimg9.ibsrv.net/gimg/blazerf...19f83a87b5.jpg
Found some ZQ8 wheels at the salvage yard... Very sought after, but I just bought the center caps. Looks like I'll need slightly different lug nut caps to hold them in place.. To be continued! |
