Camaro SS wheels
Just bought a set of 2012 Camaro SS wheels for my 98 Blazer and I know I'm going to need spacers. Do any of yall have an idea of what width spacers I would need to even up the front and back wheels but keeping them from sticking out?
I'm going to guess from your picture album that you have a 2wd Blazer, so you'll need at least 2.5" spacers. I think that's what most of the people use that run the new Camaro wheels. The newer Camaro's also use a slightly different bolt pattern. I believe it's 5x120mm, and the Blazers use 5x4.75" or 120.65mm. You'll want to get spacers that adapt to the slightly smaller pattern of the Camaro wheels.
Yeah I have a 2wd but thanks! I was thinking either 2.5" or 3" max
When I did mine I went with 2.25 front and rear .The rims were 2.0 inch different back space. You do the math. I am going to turn off about .5 inch from the front so it doesnt scrape the back of the wheel well. Take a look at my page. Make sure that they are hub registered inside and out.
| All times are GMT -5. The time now is 09:27 PM. |
