can I fit these?
Can I fit 35x12.5 tires on an 01 4wd 4d with 3.5" susp lift and 3" body? Any help is appreciated!
search function is your friend
https://blazerforum.com/forum/tires-...n-i-fit-72543/ |
Possibly i had a 1992 sonoma with a 6 inch suspension lift and a 3 inch body lift and i had 38's with plenty of room left i could have done 40's. Just measure your clearances. Its not difficult. Just take a look at every where you think your tires would rub and measure. Turn the wheels all the way to right and left.
The tires you want there will not fit on a factory rim you would have to get about a 9 inch wide wheel to accommodate that wide of a tire. The tires on my Sonoma were 38x15x12.5 and i had 8.5 inch wide wheels on mine
Would spacers help at all? I want a little bit sticking out the sides anyways
Originally Posted by Juggalo1003
(Post 586883)
Spacers wont help your rim width. If you put 12.5 inch wide tires on 7 inch wide wheels, your gonna get some goofy ass tire wear, because it will pull the edge of the tires in and make the middle of the tread surface bulge out, and that with ruin your tires. Trust me you don't want to do that 35x15x12.5 tires aren't cheap. The only thing spacers will do is pull the wheel away from the hub and put your wheels further out to the sides of the truck. Spacers just give you more clearance away from the frame. Mine didn't have spacers and the wheels and tires that i put on, stuck out a good 4 inches from the fenders so i had to put fender flares on.
(Post 586929)
And I can't seem to load it up here! I have it in another thread of mine
With a 3.5 inch suspension lift and a 3 inch body lift you shouldn't have any issue with clearance. Where i would think you would have your issue is trying to mount those 12.5 wide tires to a 7 inch wide rim. Other than that i don't think you will have much of a problem.
