-   Tires and Wheels (https://blazerforum.com/forum/tires-wheels-13/)
-   -   corvette disc brakes (https://blazerforum.com/forum/tires-wheels-13/corvette-disc-brakes-14241/)
felonyblazer96 11-06-2007 05:45 PM
since corvette tires will fit my 96 blazer will the disc brakes fit also?
Hanr3 11-06-2007 06:12 PM
RE: corvette disc brakes
good question. I don't know.
swartlkk 11-06-2007 08:07 PM
If you can find some way to mount the caliper, probably. I am not aware of any bolt on kits. To move up to a larger rotor, you will need a bracket to move the caliper out to the proper positioning. The steering knuckle is very different between the two, obviously.
Another thing you will have to worry about is the brake bias which will dramatically change with larger brakes.
blazin97 11-06-2007 09:19 PM
It is possable. There is a guy at my school that did it to his '00 s10, it stops on a dime, but I dont know how he did it.
felonyblazer96 11-06-2007 10:45 PM
does anyone know what year the corvette has to be to perfectly match the blazers wheels.?
drperry 11-07-2007 04:32 AM
All of them will fit...
Backspacing might be off due to 2wd/4wd, but all the ones with lug nuts should be the same bolt pattern...
As for the brakes... As long as you can mount the calipers it should work...
I'd love to do the swap myself, but I highly doubt they'll fit the stock rims, lol.
Which I'd rather not lose, as I like to play in the mud...
ccajun4real 11-23-2007 05:44 PM
Anyone ever find a DIY on this brake swap? Thanks
Cajun
