corvette rims...
ORIGINAL: djbass_mekanik
i know the bolt pattern is the same, but about the offset?? will they rub?? i want to do the zo6 18 x 9.5... and i plan to lower my truck 3/3... u guys think they will rub?? can that be solved??
you NEED spacers....2.25" or 2.3" for the front, and a 2" or 2.25" for the rear.This if for any 2wd s10. Now if you had a 4x4 s10 the wheels would bolt right up with out any spacers.
for more info check out http://www.s10forum.com/forum/showth...light=corvette
ORIGINAL: xtucking22s
And corvettes have 9.5" on the back and 8.5" wide in the fron, you should do the same to minimize rubbing or else with a 9.5" wide rim on front your going to rub.
so is ther 18x8.5??? i was chekin all over and the black zo6 rims ar either 17 or 18x9.5... i didnt see any 8.5....
Front 17" x 8.5"
Back 18" x 9.5"
There is no such thing as far as i know as a 18" x 8.5"
Im pretty sure Im right....but just look around and see what you can find. I never looked into corvette rims so I didnt research it all that much, i just read posts in s10 forum all day long and I have seen A LOT about corvette rims.
here you go. if you got these, these will bolt up just fine with no spacer. What you need is between a +10 mm or +15 mm offset with about 5.5" backspacing. Take a look
http://customwheelsmarket.com/cwm-to...7861b-cam.html
ORIGINAL: XBlazer01
The rims on my dads 06 vette is 18" front 19" back not sure on the ofset tho lol
