-   Tires and Wheels (https://blazerforum.com/forum/tires-wheels-13/)
-   -   Did all 2-door Blazers come with reinforcement for swing-away tire carrier? (https://blazerforum.com/forum/tires-wheels-13/did-all-2-door-blazers-come-reinforcement-swing-away-tire-carrier-101796/)
Xander12 06-08-2020 02:01 PM
Hey everyone, I have a 98 2-door Blazer. The spare just sits in the trunk laying down. I see lots of things about fitting a carrier to 4-doors and all the things you have to do. Do you need to do this for 2-doors as well? How can I tell if it has the reinforcement? Thanks!
DonL 06-08-2020 03:10 PM
Easiest way would be to remove the plastic mold that cover the rear quarter panel on the inside of the blazer, you should see a small piece tacked to the inner side of the body.
Xander12 06-08-2020 07:27 PM
will do. thanks!
DonL 06-08-2020 07:35 PM
No problem, it should be without 6-8 inches from the lower corner of the window that just above the tail light. If you dont see a piece with nuts welded to it, the you wont have it.
I've also wondered this as I've been in the search of a second vehicle, I've kept an eye on 2 door blazers and wondered if it's as easy as punch, drill, install. The other part I'm wondering is the tail gate, if it has that reinforcement as well...
christine_208 06-08-2020 08:20 PM
Here are a couple pics I grabbed from a website that showed the nut on the inside of a 2dr ZR2 that came with the external tire carrier.
https://cimg4.ibsrv.net/gimg/blazerf...8686a72a67.jpg
https://cimg5.ibsrv.net/gimg/blazerf...31756cd90a.jpg
