Fender Flares
Hey there...I am looking for cheap fender flares for my 03 Blazer 2Dr 4x4...Any suggestions??
RE: Fender Flares
Cheap and fender flare shouldn't be used in the same sentance. Your best bet would be to find a set of ZR2 flares to use (will only work on 2dr).
RE: Fender Flares
hey i've recently been reasearchin fender flares tryin to find the cheapest ones i can (i'm just lookin to cover the edges of the wheel wells to help prevent rust) and the cheapest ones i've found so far r these
http://www.jcwhitney.com/autoparts/P...013135/c-10101 i did the search for a 94 blazerbut i'm pretty sure they make em for all kinds of trucks and u should be able to get them for ur 03 |
RE: Fender Flares
Can you bolt up Zr2 fenders or just the flares them selves to a non Zr2? Or do you even need to take the whole fender?
RE: Fender Flares
Swartlkk......Aren't the wheel openings on the Zr2 different than the Non-Z blazer???
RE: Fender Flares
I don't believe there are any body differences between a ZR2 and a non-ZR2.
RE: Fender Flares
To the best of my knowledge, the ZR2 fenders have a lip that protrudes from the fender for the flare to rest on. JCWhitney doesn't have a picture but the product description here is different than the non-ZR2 fender here. I have read on another S10 site that it's a pain in the rear to get the flares to fit without the extended lip.
RE: Fender Flares
darn i got excited when i thought it might work
RE: Fender Flares
hmmm.so aZR2 flares would work on my 03 LS 2 Door???
RE: Fender Flares
ORIGINAL: swartlkk Cheap and fender flare shouldn't be used in the same sentance. Your best bet would be to find a set of ZR2 flares to use (will only work on 2dr). |
