-   Tires and Wheels (https://blazerforum.com/forum/tires-wheels-13/)
-   -   help!!!! (https://blazerforum.com/forum/tires-wheels-13/help-69825/)
semajelah Apr 10, 2012 02:17 PM
help!!!!
i have a 2004 4door 4x4 i just bought some wheels for it and out them on and the front ones stick out and the back dont. they arent off set wheels so idk whats wrong or how to fix it. i wouldnt mind if the back ones stuck out to even it up a little bit but it bugs me with just the front sticking out. all help is much appreciated. Thanks!
warthogdriver Apr 10, 2012 03:51 PM
to balance the rear and front you need to buy 1.5" wheel spacers(adapters)
look on ebay for camaro - corvette hub centric.
thats guessing that the backspacing is the same on all the wheels you put on.
tibby Apr 10, 2012 04:11 PM
Assuming you have a 4wd blazer, and all the wheels are the exact same, this is normal. I don't think it looks that bad. But I also would never put spacers on my wheels because IMO they aren't safe.
But if you decide to get spacers, at least get quality hub-centric spacers. If you get the cheap ones or you get lug-centric, they are more likely to snap and your wheel fall off.
semajelah Apr 10, 2012 04:36 PM
Can I get spacers since the wheels I got aren't universal? They only have 5 holes and those line up with my studs. Don't soacers change the lug pattern for the wheels?
warthogdriver Apr 10, 2012 04:53 PM
yes,
search ebay for camaro - corvette spacers hub centric.
those two cars have the same lug pattern as the s10 blazer.
exactly what i use
semajelah Apr 10, 2012 05:11 PM
does it matter what year camaro or corvette? and can i swich back to my factory wheels and still use the spacers if i wanted to?
i think im just confused on how spacers work. do they bolt to my studs and change my lug pattern? sorry im not very familiar with these
Brian_D Apr 10, 2012 06:49 PM
Yes, i just bought some from ebay, from a seller called cjbargins. msg him. he will point you in the right direction.
I couldnt stand the back not lining up with the front, iv had them on for about 3 days now, and i love them so far.
They bolt right up to your hubs. and the wheels bolt up to the spacers..
Just make sure you follow the directions to the T, as in torqing everything to 95 pds
Here is the channel on ebay.
http://stores.ebay.com/CJ-BARGINS
warthogdriver Apr 10, 2012 06:52 PM
edit....didnt press reply fast enough ^^^^
look at the first page of my build thread...link is at the bottom of my sig pic...scroll down and look at the pics.
this is what i use.
WHEEL SPACERS ADAPTERS CHEVY S10 CAMARO CORVETTE 1.5" | eBay
have had them on for almost a year running 33's no issues at all....know that i am not a heavy offroader though.
Brian_D Apr 10, 2012 06:57 PM
hehehe
semajelah Apr 10, 2012 07:30 PM
you guys are helping me so much. Thanks! but i looked at the ebay link and i can use them even tho the wheels i have match the factory lug pattern is that correct? and 1.5" will even them up right? im running 235/75/15 all the way around.
