help with tires.
I'm in the market for new tires and I have decided on the BFG All Terrain T/A but I dunno what size to go with........My blazer is the stock height and it is on the stock rims (15's). I want the biggest size tire I can put on... Minor rubbing is ok.
RE: help with tires.
you can fit 30x9.50's without major rubbing stock. might even be able to squeeze 31x10.50's with a tbar crank but you might have to get shackles for the back and still might have to trim the fenders a little
is there a way of raising the front end with out the lift.....someone told me there was.....
yeah, it's called cranking your torsion bars.
ok well im new with the blazer and I dont want to screw something up.....is there a how to on it?
that can be found here:https://blazerforum.com/m_78641/tm.htm
| All times are GMT -5. The time now is 06:30 PM. |
