Help!! Wheels hitting on brake calipers??
2 Attachment(s)
I am trying to install Camaro rims on my 98 4x4 Blazer 4dr. The problem I am having is the back of the wheels are wider (7.5") then the stock (6.5") and they are hitting on the brake calipers. What size wheel spacers would I need? I want to keep it as close as I can because the rims are 5.5" offset with 10" wide tires and already stick out. Or could I grind a little off the calipers so I could go with a thinner spacer? I have included photos with the parts that are hitting highlighted. Thank for the help.
If it is only hitting in those two small areas, I would grind a bit off of the caliper bracket to clearance it more.
If you knew someone with a lathe big enough to mount the wheel in, you could machine a relief into the rim wheel mounting surface. |
Looks like all you need is the thinnest wheel spacer IMO.
Those two points stick out the most the rest is about flush. As far as I could tell they hang out about 1/4". I was thinking of 9/32 or 5/16 wheel spacers. Just not sure if 1/32 or 1/16 would be enough clearance. I think I could get away with some grinding in the caliper it is very meaty at that point.
Mine was doing the exact same thing on my 2000 LS 2dr, I put a 1/4" spacer and i dont have any contact or issues.
yeah i would just grind that off with an angle grinder.
grind= free spacer= more $$$ driving a blazer im sure there are more important things to spend that money on besides spacers. |
The spacers i bought were 5 dollars a piece ($20 = Totally worth it)
Grinding on Brakes= Not safe Also= LOTS more $$$$ when you mess up or sh*t tons of $$$$ cause a malfunction happens and run into the person you are driving behind... |
Griding a bit of metal on that area will not harm anything... That caliper is not a moving part and IMO would be quite safe, I wouldn't take off any more than you need too though.
Originally Posted by matthew.chapman1
(Post 241441)
sorry i would rather grind some caliper than buy cheap, poor quality spacers.
i have a set of truly hub centric spacers on the back. they ran me about $60 and that was cheap. true hub centric spacers are the only way to go if your going to use a spacer. |
