I need input...
Old Aug 1, 2008 | 12:26 PM
H8RBLZR's Avatar
H8RBLZR is an unknown quantity at this point
Default I need input...
I have a 1993 Chevy Blazer, and for being a 21 year old chick, by default I'm a little bit vehicle stupid. I mean,my dad helps me do whatever it needs, I know BASIC Blazer knoweledge haha.So I need a little help from Blazer people! Well the tires on it are ridiculously old, and I need new ones. I also wanted to put a decent lift on the thing, so I'm thinking I should just go ahead and do it all now. I want my truck to look pretty meaty, but not over the top, you know? I was thinking of a 3" lift, with whatever tires will fit with that. Any ideas? I also am looking for a not so grossly expensive way to do this. I was considering looking at gently used tires as well.
Does anybody have any advice?
Old Aug 1, 2008 | 01:09 PM
cliro's Avatar
cliro is an unknown quantity at this point
Default RE: I need input...
3". you can put a 3" body lift and you should be ble to put 31's on it.
run a search and you should be able to find lots of info on this.
Old Aug 1, 2008 | 02:58 PM
H8RBLZR's Avatar
I searched a bit, and I'm seeing some people say that I could possibly put 33" tires on it with a 3" lift.
Yes? No?
Old Aug 1, 2008 | 05:33 PM
Hanr3's Avatar
The short version.
2" body lift and you can fit 31" tires.
3: body lift and you can fit 31" tires.
To fit 33" tires you have 2 options.
6" supsension lift.
OR
3" body lift and trim about 2 1/2" off the front and back of the fenders.
your best bet for inexpensive.
30" tires. They will fit with no lift.
IF you want to fork out the $300 for the body lift and 1/2" more ground clearance. its your money.
Old Aug 1, 2008 | 05:51 PM
NVANZEE's Avatar
you should be able to fit 31s with an add-a-leaf or shackels in the rear and a t-bar crank in the front.
Old Aug 1, 2008 | 09:33 PM
Hanr3's Avatar
ORIGINAL: NVANZEE
cranking the t-bar 2" will eat front end parts, not too mention the rough ride will chatter your fillings outon any sawtooth roads.
Stopphn
Headers, Intake, & Exhaust
May 30, 2008 03:54 PM
dbleon
Jan 12, 2008 12:36 AM
volrath169
Engine & Internal
Jan 12, 2007 07:07 PM
bmmont
Dec 19, 2006 01:19 AM
brad
Sep 2, 2005 01:47 PM
