I want these...
OFFROAD PACKAGE:
Rims: AR-136 (American Racing) Tires: 31x10.5x15 (Dunlop Radial Mud Rover) 2.25" spacer on rear 1.5" spacer on front stock suspension height DAILY DRIVING PACKAGE: Rims: Stock Tires: 235/75/15 (Yokohama Geolander H/T-S G051) Discuss! |
RE: I want these...
sounds pretty good for both offroad and d.d. you have any pics of the offroad rims and tires
RE: I want these...
You're not going to fit them under your truck without doing some basic lifting (body lift + shackles + tbar crank). If you didn't want to do that, you'll need to down size that to a 30" tire.
RE: I want these...
ORIGINAL: swartlkk You're not going to fit them under your truck without doing some basic lifting (body lift + shackles + tbar crank). If you didn't want to do that, you'll need to down size that to a 30" tire. |
RE: I want these...
There are many threads about lifting and what is required for a particular tire size in the Lifting Tech section.
For lift shackles, if you know how to weld or know someone that does, they are quite easy to make up yourself. Tbar crank is quick, easy, and free. It also has been discussed in quite a few other posts in the Lifting Tech section. The body lift is where a few different manufacturers come in, but I don't know if anyone has had problems with any of them. Or atleast I cannot ever remember hearing anyone even mention what brand they purchased to say whether they were good or bad. |
RE: I want these...
most bodylifts seem to be made by Perfomance Accessories... i think superlift and rough country might also make body lifts.
check out SYNERGY OFFROADit is run by a member on this site and everything they sell is meant for s-series trucks or the colorado/canyon trucks. they seem to have pretty good prices on everything too |
