iroc 16s?
will the Camaro IROC 16 in rims and tires fit on the 99 bravada all-wheel drive? what tires would I have to put on those 16s, tallest, widest? I found a Sweet set of gold clads.
What year of the camaro?
honestly no idea. It was not mentioned. it was mentioned that they are the 5 on 475 bolt pattern but backset was also not mentioned. they look very similar to the Blazer 5 Spoke stars with the bow tie center cap ... I wish I was smart enough to know how to link the craigslist pic into this thread. I thought they only put the Iroc nameplate on the late 80s early 90s Camaro?
There was some on the 70s models not sure on the bolt pattern on those. If it's the 80s/early 90s as you describe with the 5x4.75, then yes they will fit like a 2wd rim. I used to have a set on mine, as many others have on theirs...
thanks hopefully I can pull the trigger on them before they disappear.
| All times are GMT -5. The time now is 05:59 PM. |
