largest tires for a 99 blazer with no lift?
I have a 99 chevy blazer 4dr 4x4 base model, I want to upgrade the wheels & tires.
I want to up grade to 15x8? & the widest, basically biggest offroad tire I can, what sizes of tires would work without body modification (trimming,lift) |
It depends on the wheel offset. The further the tire sticks out, the smaller the tire you can fit. Stock wheels can fit a 31" tires with some rubbing against the frame and rear of the front fender. A 15x8 wheel with a RWD offset will reduce your tire size to nearly stock.
Originally Posted by drealot
(Post 585628)
I agree. Your rig can accommodate 30x9.5x15 tires with no modifications. If I were you I would put some lift so I can have a more aggressive set of tires for off roading.
31x10.50 will rub with no lift so yeah 30s
