looking to put bigger tires on my blazer
What is the biggest I can fit on my stock 2wd 2002 blazer right now I have p235/70r15 what's a bigger tire I can run without rub
Sure been discussed a lot. Have a look trough the threads in the 'Tires & Wheels' section.
Okay thank you
From listening to other members 30" would be the biggest you could fit without modifications.
Eh yeah 30x9.50x15 is about it. I know that will work with the 4x4's so should work with the 2wd. If you rub you could always slap a pair of shackles in the back and some spring boosters in the front.
Ya I read about the 30" tires but I realized it was for 4x4 so I wasn't sure bout 2wd also I'm most likely be putting the tires on the stock rims and what would the dimensions of a 30" tire for the stock rim? Which I think is 7" wide
Im getting ready to try and put 30" on my 2wd. Will let you kno how it goes.
| All times are GMT -5. The time now is 09:50 PM. |
