maximum tire size ??
What is the maximum tire size for a blazer 2000 w/ stock suspension 31" or 33"
Neither! Try reading this and you will have your answers. https://blazerforum.com/forum/tires-...n-i-fit-72543/
I run 31" with t bar crank, shackles and two inch body lift and it will still rub occasionally
you can pull off 31s stock with fender cutting if your not to worried about cutting your pretty truck.
29 or 30 if you trim
Keeping your truck stock the biggest I would suggest you can safely go without doing any trimming or modifications is a 30x9.5x15 or a 255/70/15. I like the 255/70/15 better myself because it's a little wider.
Originally Posted by dustinhxc
(Post 605075)
Thanks
