-   Tires and Wheels (https://blazerforum.com/forum/tires-wheels-13/)
-   -   New wheels or spacers (https://blazerforum.com/forum/tires-wheels-13/new-wheels-spacers-89721/)
lazyboyjake May 2, 2015 11:43 PM
I have a 2wd Blazer that I put a 2" suspension lift on and tires that are somewhere between 30" and 31". The tires rub only at full lock and I know my best option would be to find some wheels with less backspacing but I'm having trouble finding any wheels with less than 3.75 backspacing. My wheels are the factory with 4" backspacing so would the quarter inch really make a difference or should I get some spacers? If I should get spacers what size would you suggest?
lazyboyjake May 2, 2015 11:44 PM
Also, is there any way to put a .25" space between the wheel and hub to test it out without having the new rims?
Jamaroon May 4, 2015 10:50 AM
Yes, you could space them out 1/4" to check clearances. I wouldn't drive around like that because the studs might be getting too short and not have proper thread engagement.
newguy May 4, 2015 11:02 AM
http://www.summitracing.com/search/p...rder=Ascending
Jamaroon May 4, 2015 11:15 AM
I tried searching quickly for a definitive answer but couldn't find anything quickly. I thought 2wd wheels had the same specs as third gen Camaro wheels, in which case they would have a 4.5" backspacing, not 4".
lazyboyjake May 4, 2015 06:21 PM
Thanks for the help you guys! I completely forgot to check summit racing
newguy May 4, 2015 08:06 PM
pretty sure with those rims you will need 1 inch lug nuts for them. Different angle on the cone part. Summit sells them also
newguy May 4, 2015 08:11 PM
http://www.summitracing.com/parts/krc-8203/overview/
lazyboyjake May 4, 2015 08:35 PM
Yeah, I was gonna get new lugs if I got new wheels. Thanks for the link.
newguy May 5, 2015 02:41 AM
just saying, with those rims you CANT use stock lugs
