newb tire/wheel question
this is what i would like to put on my 4dr 4wd 99 blazer.
i plan on doing a 1.5" t-bar lift and 2" shackle before taking this step. cragar soft 8 (http://www.summitracing.com/parts/CRR-3977834P/) 16X8 backspacing 5 inch offset +12.00 mm with a 255/70/16 or 31X1050 (assuming will rub with 31) from what searching i have done this should work. looking for feedback/suggestions for what looks good(pics) before i go out shopping. thanks. |
you should be fine with the 255's if you do have to trim it shouldnt be bad at all.
Yep, that setup should work just fine.
thanks for the quick response guys it is much appreciated.
i have had my blazer for awhile and just now getting into customizing. bandidolenny nice ride, blazers like that make the diff. thanks again. |
Thanks... but I gotta admit, there are many nice Blazers here.
true, i like having the pics available to see what has worked and what hasnt.
these forums are a great place to get ideas for projects. |
where did you get your fender flares? (trim)
would warthog be able to fit those wheels/tires on a stock blazer?
