Painting my Stock Rims(98 Blazer)
So I have a Black 1998 2-Door S10 Blazer, and I had recently seen a picture of the same model and color as mine but with the stock rims painted black. I loved the way it looked so I was wondering if anyone could tell me the best way to go about painting my rims, without having them chip easily. They are the same rims seen in the picture of the red Blazer at the top of the site (Not the twirls).
I have the same rims. I'm going to be painting mine this weekend. I just plan on scuffing them up with sand paper or scotch pad and painting it with a can of black spray I got at the local dealership. I'm not sure how well the paint in going to hold with the texture on these rims, but I'll let you know how it goes and post up pics.
Originally Posted by Sisk
(Post 252194)
your best bet BlkonBlkBlaze and Sisk, is to have the rims stripped, then painted (to whatever colour), and re-cleared so they'll last. another option is for powder coating, 'cause that s**t doesn't come off. you can also get different finishes (high gloss, satin, matte) to suit your style. |
(Post 252241)
that's not gonna last long Sisk. remember, the rims have that clear coat on them, and if they're 10 yrs old, they'll probably have some peeling/chipping issue (especially with our Canadian Winters).
your best bet BlkonBlkBlaze and Sisk, is to have the rims stripped, then painted (to whatever colour), and re-cleared so they'll last. another option is for powder coating, 'cause that s**t doesn't come off. you can also get different finishes (high gloss, satin, matte) to suit your style. If you want something permanent then power coating is definitely the way to go. |
I would definitley recommend a clear coat. Sand it down with a rough sandpaper followed by a very fine sandpaper (like wet-dry). Then prime it and let that dry and then go over again with superfine sandpaper (you may want to sand again with supre fine, i never have at this point). Apply a final coat of primer and let dry. Paint the rims 2 or 3 times and then put a nice clearcoat on top of that!! Good luck.
Thanks alot guys, that gives me a much better idea. I was thinking pretty much along the same lines as you though Sisk, picking up some black spray and giving them a quick sanding. The only thing I was worried about was having it peel easily seeing as how winter is coming up and all, but we'll see how it goes. I'll post up pics as soon as I can, I look forward to seeing yours as well Sisk.
Originally Posted by BlkonBlkBlaze
(Post 252279)
i painted my stocks and they came out great.
sanded them down (hardest part) high heat engine paint 2x satin clear3x good luck |
(Post 252279)
(Post 252313)
I'm planning on doing them Saturday. Hopefully all goes to plan. It's a long weekend up here (Thanksgiving in Canada) so I should be able to get it done one way or another.
Originally Posted by 00whitezr2
(Post 252353)
i painted them two weeks ago.i scuff sanded them.and also dont forget to always use primer. i did two coats.i wound up re doing two rims cuz they werent perfect,and it was extremely hard to remove the paint.had to use airplane paint stripper!so i think they'll last through the winters.just dont be shy on the clear coat.and if not im a pro at painting rims by now!did my wifes scion rims too
