pictures of wheels!!
i am purchasing a set of 15x8 wheels with 4'' backspacing, and will be mounting a set of 30x9.50-15 bfg's on them, i know the factory wheels use close to a 6'' offset, so the new wheels will probably stick out around 3 extra inches, anybody have a pic of their ride with this wheel offset, if it looks to bad i can get a set of fender flairs, but just curious!! Thanks
Here are some pics of mine. They're 15x7 with 4" backspacing with 31x10.5 tires :)
http://img189.imageshack.us/img189/3386/img1283r.jpg http://img196.imageshack.us/img196/3856/img1285ao.jpg |
anybody have pics of the 15x8 rims with 4'' backspacing and bfg all-terrain tko tires, 30x9.50-15?
mdehoogh - do you have a lift?
I put these on my 98...
https://blazerforum.com/forum/tires-wheels-13/got-my-new-wheels-today-30286/ |
I have 15x8s on my truck with 31's. If u dont plan pn lifting your truck the 30's will rub with that offset. If you are sticking with the 30's just get 15x7's you should be ok with that
bandidolenny....like them wheels, look great on the truck, where did you get the fender flares? are them flexy flares?
Originally Posted by a1c_franz96
(Post 405733)
do you have any problems rubbing or did you have to trim?
well i got my 30x9.5-15 bfgoodrich TA KO's today, waiting for the rims to show up and hopefully get them mounted by the weekend, planning on a very mild t-bar crank and maybe shackles, will post pics, i am planning on some fender trimming, i have flexy flares on the was as well, so hopefully it all works out good, and looks good! i do quite a bit of off-roading in my everyday job so will have to see how it gets around!!!
| All times are GMT -5. The time now is 09:13 AM. |
