Pro Comp's
I am looking into buying rims for my 2000 Gmc Jimmy 4wd 2dr, but know nothing about rims except that i want these:
Rock Crawler Series 98 Gloss Black Monster Mod Wheel http://i44.tinypic.com/25ziiid.jpg Im going for this look just not those tires: http://i42.tinypic.com/35ddaix.jpg Im 100% sure i want 15 inch rims, and that i need a 5 on 4.75 bolt pattern. i dont want too much off set but a little would be nice i have no clue on how much Width, Backspace or max load.. can someone please help! |
Backspace for stock is 6" and 8 inch width IIRC.
There are alot of threads around about rims and tires and whatnot. Try a Search! |
thanks man that helps alot.
i will probably just get stock backspace |
Im not sure you can get them that big. I remember only seeing them up to like 5 maybe 5.25. but combined with offset you could probably get there.
hmmm..........i thought 4 1/2 inches was the maximum. or was that on the super8's from Cragar?
oh ok i see what your saying now..
so pretty much the higher the number is on back space the less offset they will be?? So would this fit with no scrub?? but sit have a little offset, but not alot?? Lug Pattern: 5 on 4.75 Width: 8.00 " Backspace: 3.75 " Max Load: 1600 lbs |
I have the same rims only the d-link ones. get the ones with the 4.5" backspacing you will be fine.
The less the backspace number the more they will stick out basically.
Offset is how far the mounting surface is from center. |
(Post 329319)
does the max weight even matter??? it ranges for 1600 to 2000lbs |
I don't think so? since a blazer weighs roughly 4000lbs and my wheels are holding up just fine. and yea my wheels are 15x8s with 4.5" backspacing. I would image the round hole rims are almost exactly the same as mine
