Question
As we all know finding rims for jimmys or blazers is kind of tricky. I found a set of rims with tires very cheap. I have the 98 jimmy and I believe the batter is 5x120.65?? Anyway the rims I found are going to fit. Does anyone know where I can buy some adapters? The rims are the exact style and size I want and for the price I can afford to by adapters I believe
You can do a search online it will bring up many places.I`ll let you know in advance those adapters arent cheap.
I've found a few sets I was just wondering what good brands were. and $300 isnt too bad
I have no experience using them sorry I cant help you there maybe try google and see results you come up with.
I don't know about any brands of wheel adpaters, but as long as they are "hub centric" or "even lug centric" you should be good.
i've been told to go with hub centric. The lug centric can cause wheel bearing issues
How does lug centric cause bad wheel bearings?
Any thing that puts a wheel out or in farther then its supposed to be can cause bearing problems, i.e. different offset wheels or wheel spacers/adapters. |
the guy at the rim shop said lug centric but more strain than lug centric
check http://www.summitracing.com/ i got my rock crawlers for $50 each!
Im pretty sure wheel spacers are illegal in some areas. the adapter will move the tire out further as well. too far and you'll get clearance issues.:icon_twocents:
