Question about 22inchers
Hi guys i did some searching but im not great with different sizes of rims and all the offsets and stuff so i thought i would post my exact question with the info and get the right answer lol..
So im looking at buying a set of 22inch rims 22x9.5 with a +15mm I was told they will stick out just a tiny bit but they will fit perfectly.. So will they lol? Also the rubber i was quoted to get was 265/35/22 So can someone let me know if that would work BTW i have a 2001 2dr blazer 4X4 |
They should work, there is a kid around town here that I'm pretty sure has the same size you're looking at (maybe less offset). They stick out about an inch and a half, he did have to crank his torsion bars so they wouldn't rub though.
See im planing on getting it droped 2-3inches too but i guess with the rims and body kit i wouldnt need to lower it then?
you should be ok clearance wise. If you drop it you will probably run into clearance problems.
i might be better off trying to find 20's with the 15offset but the 22's were nice and really good price...
but then with body kit and then im getting the belltech drop shocks not sure if this all will work lol |
