question about backspacing
i am looking at the craiger soft 8,i found on here the factory backspacing on 99 jimmy is 6" but i can't find any with that backspacing.what is everyone else running on these wheels?it is a 4x4 thanks mike
Originally Posted by mross45640
(Post 425355)
Oh a 15x7
I have the same question I was looking at 15x7 rims with 235/75r15 tires on them will they rub against the frame in the front when I turn? And does anyone have 15x7's on their blazer?
98chevyblazer, most Blazer's come with either 235/75r15 or 235/70r15 on 15x7 wheels so no, you won't have a problem.
mross45640, I think the highest backspacing I've seen on cragar 15x7's is 4.5" Unfortunately, there aren't many wheel options with the correct 6" backspacing and 51mm offset. I am running 15x7 with 4" backspacing and really like the look of the slightly wider stance. You shouldn't encounter any problems if you're using a stock size tire. I went up to 31x10.5 and had to trim my fenders as well as crank the tbars some in order to have enough clearance to turn properly. |
So I shouldn't have a problem even though mine on now are 15x6?
Originally Posted by 98chevyblazer
(Post 425965)
Do you have any pics with the wheels I could see?
(Post 426112)
Yeah there are some pics in the link above.
Here's another pic that kind of shows the stance http://img153.imageshack.us/img153/8959/dscn0834s.jpg |
