Replacing worn tires
Old Oct 20, 2006 | 06:50 AM
SDimeBlazerlady's Avatar
SDimeBlazerlady is an unknown quantity at this point
Default Replacing worn tires
Well here goes a odd ? i have 235/75/15 BF Goodrich A/Ts on my 87 they r very worn ...so i need new tires....1 i wanna go back to a all season and 2 i wanna go back to a 205 or 215 will this cause my speedo to be off? Thanks
Old Oct 20, 2006 | 08:17 AM
DetroitMuscle's Avatar
DetroitMuscle is an unknown quantity at this point
Default RE: Replacing worn tires
Yes it will.
Old Oct 21, 2006 | 01:06 AM
Hanr3's Avatar
Depends. Is your speedo currently correct?
Pretty sure the factory tires on '87 was 205 or 215's. Should be on the door sticker if you still have it.
Then if no one changed the speedo gear, going back to the factory sized tires will make your speedo correct for once.
If someone changed the speedo, then yep, it will be off. Like 3mph at highway speeds.
kmartin
Oct 3, 2014 09:54 PM
fred96
Lifting Tech
Apr 17, 2009 06:23 PM
BlackOnBlack
Jun 24, 2008 11:52 PM
Yooper
Apr 3, 2008 09:41 PM
ZLover4Life
Feb 25, 2008 06:40 PM
