-   Tires and Wheels (https://blazerforum.com/forum/tires-wheels-13/)
-   -   the right wheels, rims for the right look! (https://blazerforum.com/forum/tires-wheels-13/right-wheels-rims-right-look-35701/)
kikkegek 10-10-2009 04:44 PM
please help.
Our Blazer looks like this:
I personally think that our wheels are to much "under" the car. This makes it look high and thin. Where as I want it to look wide and fat! Like the next picture below
http://94.100.114.148/680150001-6802...36_6_dvnn.jpeg
and I want it to lok more like this sub
http://img93.imageshack.us/img93/7065/dsc6636e.jpg
Please help. What to do to get this look?
Sisk 10-10-2009 04:49 PM
You're looking for wheel spacers. it will add backspacing to the tires and make them stick out like that.
They look like this (the purple part):
http://www.explorer4x4.com/wheel_spacer.JPG
Some reading material too if you want to know more: http://www.explorer4x4.com/wheel_spacers.htm
Also, you may want to get some wider tires...off road or mud tires tend to look a lot thicker. On a stock height you'd be looking for a 30x9.5R15 tire in mud or off road style.
[email protected] 10-10-2009 08:47 PM
i just adding 1 inch(front) and 2 inch(rear) adapters to my truck the mak my wheels/tires sit more flush.
the blazer's rear wheels sit roughly 1 inch inside the fender than the fronts do....not sure why. just take a tape measure and figure out how much wider you want to go!
i got all 4 off e-bay for 140 shipped from a company called "ezaccessory" and had them in 2 days.
kikkegek 10-11-2009 02:55 AM
I have read that putting in spacers or adapters will cause unequal wear of your bearings (excuse my bad english, I am dutch).
how bad is this really?
btw: nice (red) ride! looking good!
Sisk 10-11-2009 06:25 AM
Well it depends on how big of a spacer you put on. The bigger the spacer the more stress you put on your parts. Just going with something like 1" or 2" of backspacing won't cause that much harm though.
If you're that concerned about it why not just buy some beefier tires. That way you don't have to get into backspacing. I mentioned before that 30x9.50R15 is the largest tire you'll get on a stock ride height....just look for a mud tire in that size.
kikkegek 10-11-2009 06:36 AM
how can I find out what tires will fit our rims?
Sisk 10-11-2009 06:47 AM
Take a look at the thread and discussion here: https://blazerforum.com/forum/showthread.php?t=1811
The biggest you want to go as I mentioned is 30x9.5 R15. Any bigger then that and youll probably be looking at a lift of some sort.
kikkegek 10-11-2009 07:07 AM
oke,
so right now my tires are:
235x70xR15
So in inches (/2,54) this would be:
27.5x?? R15
please help!
Sisk 10-11-2009 07:12 AM
Not quite.
A 235 size tire is 28.9. So if you got a 30" tire it would only be 1.1" bigger in diametre.
Here is a good chart if you are interested in other sizes: http://www.thefosterfamily.org/4x4/tires.html
kikkegek 10-11-2009 08:49 AM
Originally Posted by Sisk (Post 253493)
Not quite.
So if I am correct, I could also put tires with a bigger diametre and greater width, and still keep the same rims on my Blazer?
