Rim help
Rim help
I've got the 2" bl and 1.5"- 2" t bar shackle. Doing the rims and tires now. Tire will be 31 x 10.5. Looking for rims 15" x 8" with 5" BS so I don't have to trim (much). Anyone know of a rim like the Cragar D that will fit? Or other BS that might work?
Grillzy
Grillzy
Cragar's are probably the most commonly used after market rims for the Blazer. They only come in 4" backspacing though...where did you see 5"?
Anyway, if you get them they will work fine. There are tons of people running them around here, so you wont have any issues.
I am currently running the Ion Alloy 138's (Machined finish) 15x8", and they have 4 1/2" backspacing. They are not super flashy and add a nice touch to the truck, and are not too expensive.
Can't seem to find Cragars 15 x 8 with 0 off set? Are you running 15 x 7 with the 31 x 10.5 tires?
Grillzy
Grillzy
Please do not double post. It is against the forum rules. There is no need to re-post a question you just asked. Wait for the answer and you will get it.
15x7 rims will take the 31x10.5" tire without issues. It's a very common setup to run the Cragar's with 31x10.5's. Cragar's only come in 4" backspacing, which will also be fine.
i want to run a cragar 15x7 with a 4 inch bs..on a 235/75/15 tire will that fit will i rub? i have no lift or t-bar crank. HELP PLZ!! lol sorry if this is in the wrong section
You'll be fine. That size works out to be slightly smaller then a 30x9.5, which I'm running on my truck now. Grant it I have stock rims with the 6" BS, but I doubt you'll have any issues. I have plenty of clearance.
thanks for the rim help.
Grillzy
No worries. I figured since it was the exact same post it was an error. I just have to play mod .
