rim help plz
I want to put 31x10.5x15 tires on my 2000 blazer what size rims do i need to buy and whats backspaceing
you need atleast 2" of lift first then if you wanna run 31's without trimming youll have to stick to the stock rims or aftermarket rims with the same dimensions. 15x7 6"BS
i have a 2in body lift i need to install
so i dont need to get a wider rim with wider tires?
31x10.50's will fit fine on a 15x7 rim
ok ty
Soft 8 397 Series Wheel
Finish: Black Size: 15'' x 7'' Bolt Circle: 5 x 4-3/4'' Rear Spacing: 4'' so this good? |
use the edit feature in bottom right hand corner of your post...double posting is against forum rules.
if you do not want to trim you need a 15x7 wheel with 6"BS not 4"BS |
ok ty now what does backspacing mean
hey they dont make 6in backspacin on these rims
| All times are GMT -5. The time now is 06:08 PM. |
