Rim Question
I sold my 17" Racing Dynamics RGS rims to my friend a couple of months ago. Well I might be getting them back because he's going through a hard time in his life. Since i will be getting my rims back and since i need new tires I'm thinking about mounting them on my 99 4x4 GMC Jimmy. The issue is I'm not really sure if they will fit on the Jimmy. Here are the specs
RD RGS Rims: 17X8 Lug Pattern: 5x120 38mm off set Again I'm confused any help is welcomed. TIA -dave |
Your Jimmy has a 5x4.75" bolt pattern. AKA 5x120.65mm.
The rims you're wanting to put on the truck are 5x120 correct? Don't put them on your Jimmy. |
Oh i guess i'll sell them and try to get some with a bolt pattern of 5X4.75
Thanks |
That's a good idea. Even the slighest difference can mess things up!
But we'll see what others have to say. You may be able to get some adapters and go ahead and put the rims on. |
That would be great if i could. But if it's recommended i don't, then on craigslist they will go.
Adapters are fine its just not recomended to bolt the rims straight on because they're not exactly the right size.
I know some don't like it, but I have that bolt pattern on my blazer and on my Camaro with no problems. Just thought i'd put my two cents in.
Originally Posted by old 5k0ol
(Post 262221)
i dont know what kinds there are. one place to look is ezaccesories.com. make sure you have the right bolt conversion too.
Thanks I'll go on ahead and look into that.
