Rim Questions
We'll these fit a 98 4wd, the owner said they are from a 4wd but want to make sure they'll fit mine before i buy them. They were on a 92 blazer 4wd is what he said.
http://newjersey.craigslist.org/pts/346444850.html Thanks Brian |
RE: Rim Questions
Yep, those will fit.
RE: Rim Questions
If they indeed came off a S10-Blazer then Yes they will fit your truck.
I only question where they came from because of the lug bolt pattern. The S10 usea 5 on 4.75" pattern. Ford and Jeeps use a 5 on 4.5" bolt pattern. Verify they came off a S10-Blazer and not an Explorer. Either he has the bolt pattern size wrong or the model of the vehicle they came off? One will work, and the other won't. |
RE: Rim Questions
Yeah he lists that they have a 5 on 4.5 bolt pattern and as Hanr3 said Blazer's use 5 on 4.75 (I took the ones I bought for my '84 and put them on my '00) so you need him to clarify.
