Rim size bolt pattern question
I have a 2001 Blazer S10 2WD and I've been shopping around for replacement rims/tires. I'm currently running 235/70/R15 (stock) rims. I don't want to have to worry about my messing with my speedo, so it has to be a bolt on solution that won't change that.
Couple of questions. What size bolt pattern does the stock rim have? What size tires will fit on my stock rims? (235/75/15?) Thanks for your help!! BTW, I got the train horns mounted (from another thread). It's amazing what you can do with a 2 ton jack and a sledge hammer. :-) Pics coming soon. 157db @ 200psi |
RE: Rim size bolt pattern question
The bolt pattern is 5 on 4.75"
Any tire in 15" size will fit your rim. If your running the 235/70/15 and dont want to mess up the speedo, run another set of tires in that size. Yes the 235/75R15 will fit the rim, however they are a bigger tire. Check out Cooper tires, pick a tire, and look at the specs. It will have the dimensions of the tires in inches. |
damn, he beat me to it. yeah, the 235/75's is what i put back on mine. if you can, get some uniroyal tiger paws. those are awesome tires.
i'm a fan of the cooper cobra gt. My blazer handles exteremly well. and mine is a 4x4. had a friend tell me he was impressed with how well it handles for a 2 dr. suv. Compared to a buddy's 2 dr ford explore.
Anyone plus size their rims on this model? I'd like to go to 16 or 17 inch rims. Any suggestions?
I have some 16" wheels from a Firebird on my '87 S10-Blazer. I wrapped them in 285/75R16 Cooper Discovery STT tires (32.8"x11.3"). the Firebird wheels also have a 5.5" to 6" backspacing, just like our wheels do. Check the wheel catalogs for Firebird wheels. I believe Corevette wheels also fit.
ORIGINAL: Hanr3 Yes the 235/75R15 will fit the rim, however they are a bigger tire. |
ORIGINAL: BLK85 ORIGINAL: Hanr3 Yes the 235/75R15 will fit the rim, however they are a bigger tire. And to get it recalibrated, you need to get the computer programmed for the new tires. |
Which can be done at the dealer or one of those aftermarket programmers.
I didn't get mine recalerbrated. I figured that my odometer will be off 3,000 miles every 100,000 miles. I can live with that. |
Is the bolt pattern the same for a 96 4x4?
The bolt pattern is the same on all S-Series vehicles... the only thing that changes is offset and backspacing.
How do I check that? I'm buying a set from a guy who never used them, but I have no idea what offset or backspacing should be. They're 15x10's, and I'm gonna slap 32x11.5's on them.
I hope you've got a good sized lift on the thing, or those aren't gonna fit...
See if the guy will let you test fit them, and such, then you'll see if they clear everything... I'm not 100% sure on how to measure all that fun stuff, but I'm sure you can find something in the search area... |
Well, by the time they go on, there will be a 2" body lift, fenders cut about 2", and a 2" susp. lift. I'm hoping that will give me the room.
PS: sorry for hijacking the thread. |
that should give you the room... if not, more lifting and trimming! lol
the only thing you might need to worry about is the tires rubbing the frame when turning |
Just dont turn as far.:D
Sounds like a plan. We want pics. |
Dudes...seriously, I'm starting to think I should just slap the 2" body lift on, and glue some 31's to the existing 15 x 7's...and wait until I do the solid axle front swap that I really want to do...instead of dropping the cash on fender trimming, 2" susp, bigger wheels, and big tires. Besides...I should have the cash to do the solid axle conversion this summer.
Again...sorry for hijacking the thread. |
And for the cost of the body lift to gain 1/2" of ground clearance is it worth it?
