Rim size bolt pattern question
I have a 2001 Blazer S10 2WD and I've been shopping around for replacement rims/tires. I'm currently running 235/70/R15 (stock) rims. I don't want to have to worry about my messing with my speedo, so it has to be a bolt on solution that won't change that.
Couple of questions. What size bolt pattern does the stock rim have? What size tires will fit on my stock rims? (235/75/15?)
Thanks for your help!!
BTW, I got the train horns mounted (from another thread). It's amazing what you can do with a 2 ton jack and a sledge hammer. :-) Pics coming soon. 157db @ 200psi
The bolt pattern is 5 on 4.75"
Any tire in 15" size will fit your rim.
If your running the 235/70/15 and dont want to mess up the speedo, run another set of tires in that size.
Yes the 235/75R15 will fit the rim, however they are a bigger tire.
Check out Cooper tires, pick a tire, and look at the specs. It will have the dimensions of the tires in inches.
damn, he beat me to it. yeah, the 235/75's is what i put back on mine. if you can, get some uniroyal tiger paws. those are awesome tires.
i'm a fan of the cooper cobra gt. My blazer handles exteremly well. and mine is a 4x4. had a friend tell me he was impressed with how well it handles for a 2 dr. suv. Compared to a buddy's 2 dr ford explore.
Anyone plus size their rims on this model? I'd like to go to 16 or 17 inch rims. Any suggestions?
I have some 16" wheels from a Firebird on my '87 S10-Blazer. I wrapped them in 285/75R16 Cooper Discovery STT tires (32.8"x11.3"). the Firebird wheels also have a 5.5" to 6" backspacing, just like our wheels do. Check the wheel catalogs for Firebird wheels. I believe Corevette wheels also fit.
ORIGINAL: Hanr3
ORIGINAL: BLK85
How much will this screw up the speedo? I want the BFG A/Ts and I cant seem to find them in the 235/70 15s. Also how do you adjust the speedo to be right if I were to go with the taller tire?
ORIGINAL: Hanr3
And to get it recalibrated, you need to get the computer programmed for the new tires.
Which can be done at the dealer or one of those aftermarket programmers.
I didn't get mine recalerbrated. I figured that my odometer will be off 3,000 miles every 100,000 miles. I can live with that.
Is the bolt pattern the same for a 96 4x4?
