RIM SIZING HELP NEEDED
ok guys i need help. my stock rims on my 99 blazer are 15x7, the tires are 235/70/ 15. i dont know the spacing but found the same rims on e bay and those are 4.75. my question is could i buy some 15x8s to fit my blazer without altering or adding anything , and will the tires fit on the 8's. i am looking at these rims on ebay and would like to buy them so any help is appreciated, what is the biggest tire size i canget on the 8s with no altering and rubbing? thanks
RE: RIM SIZING HELP NEEDED
A lot depends on what you want to do with your truck. Lots of offroading or no. If offroading is what you want to do then the 8" rims give you an option for 31x10.5x15, these are taller and wider than stock so there might be some rubbing issues with out a Body Lift.
You can fit the stock '70 series or go with a larger 75 series tire...with my stock rims I am riding on 235x75x15's these are better for the stock rims than the 70 series tires plus cheaper...the 8" rims would make the 70 series work better, it moves the beads out more so the sidewalls are not squeazed as much as they are with the stock rims...contact patch would fit the road better.... |
The general rule of thumb if 4.5". You can safetly run tires up to 4.5" wider then your rims. On a 7" rim you could run up to a 11.5" wide tire. Go to the 8" if youwant a 12" wide tire, although you will need to change your backspacing to avoidhitting the frame or torsion bar at full crank. However moving thewheel out with less backspacing meansthe tire will now hit the rear of the front fender.
The biggest tire to fit on a stock S10-Blazer without changing wheels is 30x10.5x15. You could go to a 15x8 or even a 16x8 rim with 6" of backspacing and run the 10.5" wide tires, you might rub the frame and torsion bar at full crank, just dont turn full crank. |
| All times are GMT -5. The time now is 06:41 PM. |
