Rims and dropping
Hello, I have a 1992 2dr 2wd s10 blazer stock. I'm looking to buy some 20" rims and was wondering what tires do i need to look for, and also will i be able to drop it any without it rubbing or having to cut anything. Thanks
probably do a 2-3 with out cutting anything, most 20's are wide though so you may run into rubbing issues when turning
personally i would get at least a 40 series sidewall to protect the rims but with 20's you'll most likely be way oversized and really screw up the speedo
theres alot of rim and tire info over at s10forum.com its mostly lowered s-series vehicles over there
ok i have found some that i really like and it says it will fit my model blazer.
http://www.wheelsnext.com/wheels-tir...17-Chrome.html
but im not sure what wheel fitment i should choose
