Rims for my blazer?
Hey everyone, i have a 2003 2dr chevy blazer with the zr2 package and i am looking for a good set of rims that arent too expensive that i will be able to put a beefy tire on for off roading. the only lift on the truck is the stock 2in body lift and i dont think im guna lift it anymore so im basically looking for rims that i wont have to modify the truck for
The factory rims are 15"x7", it's up to you if you want wider/larger.
The bolt-pattern is 5x4.75" I have a set of winter tires, and all I did was get a factory set from the wrecking yard... they weren't perfect condition though, I had to clean them up and do some sanding/painting along with a couple shots of clear. Just a set of black steel rims would work too, you'd have to be more specific if you want chrome/nice rims or just any set of rims to throw some mudders on. Sorry, but I forget what the stock backspacing is... 6" I think... SWARTLKK would know. |
the stock backspacing for 4wd is 6".
Frenchyap30- zr2's are 2" taller than regular blazers,but they do not have a body lift installed from factory. its a combination of a different suspension and frame that makes the zr2's taller. |
