S29 10.50
Simple question, would 29/10.50 super swampers fit on my 96 4 door 4x4 with stock wheels and ride height?
The 29 inch diameter won't be a problem, that's about what a 235/75/15 is, however you will rub the frame with a 10.5 inch tire, shouldn't be much though, just don't cut it full lock
or drop a few buck on wheel spacers
don't people on here mount 31 10.50 tires on stock wheels and it doesn't rub the frame??
Don't Wheel spacers cause problems in the long run?
I've had spacers (5/16) on the back wheels for about a year now and no problems I don't know about thicker ones
Oh ok, I was refering about the ones that are like 1" - 2" lol
31's require about 2 inches of lift to avoid any rubbing.
could find a set of rims with a different offset like the ones on my blazer. i found mine on craigslist for 40$ for the set of 4.
I had a set of 29x1050 swamper thornbirds on 8 inch blanck rockcrawlers on my 96 4 door Jimmy with no lift. I rubbed at full lock and if I hit a hole or bump hard. Ended up cranking the t-bars a little and thought about 2" blocks for the back. Swampers are big and heavy. My 29's were as big as my friends 31x1050 bfg's.
