Serious problem!!!!!
Hey guys. so i got a problem with my tires and i got no clue what to do. it all started last week when my tires became really loud while driving. so as a natural reaction i rotated them. ive only had my blazer about a year and didnt think about rotating them on a regular basis. so i rotated them and it didnt help. so i thought well they probable need balanced then. so i got them balanced and still they are horribly loud. like me and my girlfrend can barely have a conversation while driving. so i dont know whats wrong. can i get some advice??
All four tires don't just suddenly become louder. Does the noise remain the same at all speeds or does it change? I would look into the possibility of wheel bearings being bad. What exactly are you driving?
Originally Posted by rriddle3
(Post 274744)
Rotate your tires and see if the noise goes away, if not could be a bad hub bearing. When I had a bad hub bearing, it was quiet till it reached speeds over 45mph.
Originally Posted by nj4x4blaze
(Post 274764)
You won't have to balance them if you just did.
what kind of loud noise?..i know bad bearings have an almost dry rubbing noise just replaced the one's on the front tires of my 03 i just sold..or simply take it to a mechanic..(one you can TRUST) ask that they take it for a spin and see what they say..
(Post 274744)
if the noise is there then it's not your tires (obviously), it'd be the bearings in the diff. if the noise is NOT there, then look @ your front hubs. i've run some noisy tires before, but they never "suddenly" started to howl, unless you've had some belts break & shift. how much weight was needed for balancing? if it was excessive, then i'd start by looking @ that tire & go from there. |
well me and my brother (who is going to school for mechanics) took a more in depth look at it today and its not good :( upper and lower ball joints on driver and passenger side. and a ball bearing on passenger side. look like we get to have a fixin party next weekend :) lol
didn't think it was your tires. 'cause if it was, your tire guy should find a new line of work-broken cords/belts would've show up so easily when they were re-balanced.
glad to hear you found a solution to your problem. good thing thisproblem came up, 'cause you never want to have a bj fail on you while going down the road-or playin' in the bush! GL next weekend. |
