Speedometer recalibration
I want to put some knobby tires (like Wranglers) on my 2002 Xtreme, but the stock size is 235/60R16 and in those, knobbys are unobtainium at a decent price. So I'm looking at 235/70R16, whose circumference is 7% bigger.
As I appreciate it there is no gear to fix the speedo, you have to take it to the dealer. How much does that cost? Also, if I decide to live with the difference, are their other issues I should be concerned about? |
I don't think that small of a change would be worth recalibrating. Probably wouldn't even notice.
If you make that size change, add 7% to whatever speed your speedometer reads. Example - if the speedometer reads 65mph, you're actually doing 70mph.
https://www.discounttiredirect.com/learn/tire-size-calculator |
I'm not sure how much you want to spend on it, but I used a Jet Accu-Speed Calibrator on a Suburban once and it worked perfectly. Pretty easy to install and adjust, too.
I was wondering if 7% would make a difference in shift points, rpm, sensors information, mpg, that kind of thing, or is it just remembering to go 5 mph faster?.
Also, would a tire store have a tool like Tom A shows and they would recalibrate for me with purchase? Finally, I can get the diameter and the tread I want in a 17" or a 15" tire. What is the consensus on fitting one of those onto a 16" rim? |
I don't think you can put a 17" or 15" tire on a 16" rim. Can you not get the tire you want in 16"?
Even if you could somehow stretch it to your rim, I wouldn't want to be anywhere near you on the highway |
Find someone with a Tech 2 , I've recalibrated tire size on my 02 Astro and 05 Jimmy so I'm pretty sure it would work for you.
1 Attachment(s)
Originally Posted by puttster
(Post 700145)
Also, would a tire store have a tool like Tom A shows and they would recalibrate for me with purchase? Finally, I can get the diameter and the tread I want in a 17" or a 15" tire. What is the consensus on fitting one of those onto a 16" rim? What confused me is that there appears to be three different calibrations for the 4L60E depending on rear end ratio but these ranges overlap: A; 3.08/3:43 B: 3.08/3.42/3.73 C: 3:42/3.73 The relative shift points are at lower engine speeds for the higher gearing. (see attached) Does anyone know about these different calibrations? There might be other inputs into the ECM etc. but this is what I found. With a larger tire you have effectively changed the differential gearing ratio; i.e. for a tire with 7% larger circumference, you travel 7% further for the same number of turns of the drive shaft or that a differential gearing of 3.73:1 becomes 3.47:1. To calculate your mpg you will need to know the actual distance traveled, not what is on the odometer. With regard to acceleration; although the torque at the axle is unchanged, with a larger diameter tire the force applied becomes smaller (torque = force * lever_arm) |
Originally Posted by cleburne red
(Post 700146)
(Post 700166)
I brought it up because I saw this ad on Craigslist, someone selling four 16" tires installed on 14" wheels. https://houston.craigslist.org/pts/d...763693128.html
