-   Tires and Wheels (https://blazerforum.com/forum/tires-wheels-13/)
-   -   tire advice. (https://blazerforum.com/forum/tires-wheels-13/tire-advice-23220/)
akcalvin 09-13-2008 03:45 AM
tire advice.
so i got 32/10.5 r-15 and i dont know if i should get 10 inch rims or 8. also is the lug pattern for a 94 4x4 s10 blazer gunna be 5.5?
willjones 09-13-2008 07:08 AM
RE: tire advice.
The lug pattern for your truck is 5x4.75. And I would go with an 8 inch wide rim. The 10" wide is going to make the tire look very balloon like. Now if it was 12.5" or maybe even an11.5" wide tire then you could go with a 10" wide rim. What lift are you running to tuck those tires? You might want to also think about the backspacing to.
akcalvin 09-13-2008 01:11 PM
RE: tire advice.
yeah that what i was thinking. i got a 3 inch body lift 3inch shackle lift in back and 1.5 t bar crank in front. you think 12.5 on ten ich rims would fit with 4.5 inch back spaceing?
[email protected] 09-13-2008 03:45 PM
RE: tire advice.
Quick question whats the difference between a 235 70 15 tire an a 235 75 15 tire? will i have any issues fitting them on stock blazer on stock rims.
mdehoogh 09-13-2008 03:58 PM
RE: tire advice.
ORIGINAL: [email protected]
235/70r15 would be 27.953" tall by 9.252" wide
235/75r15 would be 28.878" tall by 9.252" wide
You will have no problems. Many Blazers (like mine) came with 235/70r15 but there were a lot that came with 235/75r15
[email protected] 09-13-2008 04:14 PM
RE: tire advice.
Thanks otnietdehoooo.
