-   Tires and Wheels (https://blazerforum.com/forum/tires-wheels-13/)
-   -   tire help 20" (https://blazerforum.com/forum/tires-wheels-13/tire-help-20%22-14555/)
redfyinix 11-18-2007 10:07 PM
tire help 20"
how big can i go with the tires and rims on my blazer because i have 15z now and when i turn the wheels in kinda deep they scrub...wassup.... a lil help...yo[X(]
redfyinix 11-18-2007 10:10 PM
RE: tire help 20"
its an 88 model 2x4
mdehoogh 11-18-2007 10:16 PM
RE: tire help 20"
i think 255/45/20 are supposed to fit well but you might wanna get some more advice from people with 20's
thegr81 11-19-2007 12:13 AM
RE: tire help 20"
What kind of lip is on the wheels?? If the offset pushes the outer rim in too close then you loose turning radius, a quick fix is spacers which will give you more clearance, other wise get different wheels!!
blznlowxtreme 11-19-2007 08:02 PM
RE: tire help 20"
you need to be sure and get your backspacing right. and that will keep you from rubbing unless you try to put a tire that is way to big for your blazer
