Tire Question
hey guys, i've got to get new tires on the blazer. I have a buddy who has a set of Uniroyal 265 75 15 for sale. Will they rub on the stock rim with no lift what so ever?
Thanks! |
Yes, you're going to have some serious rub without a 2 inch lift or beyond.
Todays tires are measured as follows...265 is the width across the tread in millimeters ..75 is 75% of the width of the tread to the rim edge...15 of course is the rim size..your tire would be a little wider and a little taller but not a lot..my opinion i wouldnt think you would need a lift, but check the turning radius (rubbing)
265/75 15 = 30.6 10.4
So in other words it's close to a 31x10.5 tire. I'm running 30x9.5 tires on my stock height, and it's cutting it close. You're looking at probably a body lift with tbar crank and shackles. Even still, you'd probably have some rubbing issues and full crank. See this thread: https://blazerforum.com/forum/tires-wheels-13/31-10-5-r15-36091/ |
