Want to fit 33's on my 01' ZR2
I have an 01' ZR2 Blazer that I just bought. It has 31 10.50 15's on it now and as far as I can tell nothing has been done to it lift wise. I would really like make it look a little more "beefy." Id like to fit some wider 33's on it. Ive always liked the way wide tires that stick out of the fender wells look. What do you think I could do to get that to fit? Would a 3" body lift do it?
I'm tryin to do the same thing my man. Btw i'm pretty sure you can only get a 2in body lift because you would have to lengthen your steering column at 3 inch.
Do a shackle/ tbar lift. And 2" body lift and you shouldn't have a problem.
i have 33's with a 5 sus lift 2 body lift and shackles and t-crank...still had to trim the fenders...dont know if you will fit them without some trimming.
^ listen to him he knows haha
i have 33x10.5 15 on stock zr2 wheels with shackels and add a leaf on the rear my back was sagging and tbar lift and light trimming...
http://i4.photobucket.com/albums/y11...8307171781.jpg |
do the fronts rub on hard impact...train tracks...bumps?
looks good...just a bit snug |
Originally Posted by warthogdriver
(Post 468827)
