want offroad tires
im looking into buying a set of 4 of these mastercrafts
http://mastercrafttires.com/us/en/Pr...ht+Truck+Tires but i have a stock 2005 2 door blazer 2 wheel drive can i fit these on it without rubbing? maybe the 30s if lucky or the 29's? |
RE: want offroad tires
30's will fit just fine. Shouldnt rub at all and you will still have full turning.
I was looking at those, too. Tires-easy.com has some pretty cheap tires (Mastercraft included), check them out before you make a final purchase.
naw its straight i get good deals from my cuz since he works parts at a dealership.
i want to get thos mastercrafts or the toyo open countrys more of the mastercrafts since there cheapest. |
i run another tread pattern of the mastercraft in 30x 9.50 r 15 has a highly aggressive pattern. i'musing them on outlaw II's without rubbing under normal circumstances....however , running backroads in west central indiana have uncovered the need for addtn'l lift beyond the t-bar crank that i have already done. even 30's will rub @ full stuff while running over the whoop dee doos.. on the other hand...the increase in traction more than made up for theneed to exercise a little common sense----------mugsy
[IMG]local://upfiles/9199/0A3251C7E0A74F60866655CD64F21620.jpg[/IMG] [IMG]local://upfiles/9199/26ECFA963E084586A72CA7C219CFA69B.jpg[/IMG] [IMG]local://upfiles/9199/F48AD3E60FA64143A0D26F09850AE73B.jpg[/IMG] [IMG]local://upfiles/9199/30C49B6C3DD449C5BDB99D1C6D0A85DE.jpg[/IMG] |
