What size spacers to use?
Old Aug 28, 2014 | 02:15 AM
BRoss99's Avatar
BRoss99 is on a distinguished road
Default What size spacers to use?
Cray Wheels - Corvette Wheels - Scorpion Black
Would i need spacers with these rims on a 2004 chevy blazer 4wd 4dr
Old Aug 28, 2014 | 10:01 PM
AJBert's Avatar
Those wheels have almost 7" of backspacing and are 2" wide than the stock wheels you have. So if you used a 1" spacer to get the correct backspacing they will stick out about 3" further than what you have now.
If you are sticking with the same diameter tire as stock, about 29", you'll be losing 2 1/2 inches of sidewall going with the 20" rim to boot. If you do any offroading the more sidewall you have the better.
These wouldn't be my choice for a 4X4 unless I were running 35's or larger. However, they are some great looking wheels.
Old Aug 29, 2014 | 07:00 AM
BRoss99's Avatar
Hey thanks for the reply after some carfull research and planning i came up with the same the back spacing is 6.5 in or so and they would stick out on the front. As for offroading i wont be doing much of the 4x4 is for canadian winters which i have winter rims and tires for.
Blazer5150
Feb 20, 2015 11:16 AM
Flyfishen
15
Nov 15, 2012 06:14 PM
Doctorvette
Nov 5, 2012 11:57 PM
Tinted
Dec 24, 2011 01:56 PM
mrprikei
Nov 23, 2011 08:31 PM
