what wheel/tire combo is my stock 2000 blazer capable of?
Im interested ONLY on the Procomp Rock crawler series...
My problem is the internet basically sucks, I'm a brand new member to this forum and my last thread regarding tires was so unspecific it got shot down. SO <LI nodeIndex="1">15x8, 5 on 4.5 Bolt Pattern <LI nodeIndex="2">Backspace = 2.5 in.<LI nodeIndex="3">Max Load = 1600 lbsor <LI nodeIndex="1">15x7, 5 on 4.5 Bolt Pattern <LI nodeIndex="2">Backspace = 2.5 in.<LI nodeIndex="3">Max Load = 1600 lbs on an unlifted 4x4 2dr 2000 blazer which would work without needing to lift and with what size tires would this work! it would make my week to have this seriously answered even though I could probably search the forum for about an hour to find it. THANKS!!! |
Your other thread was in the wrong section which was partially why it was locked.
As for tires, 30x9.5 is typically the maximum recommended tire size for a stock truck with stock wheels. Most aftermarket wheels have much less backspacing than stock wheels. Less backspacing means the wheels will sit further away from the vehicle and the further you get, the more problems there will be. The wheels you listed say 2.5" backspacing which is far too low. Stock 4x4 Blazers have 6" of backspacing. Additionally, the wheels you listed say 5 on 4.5 which is incorrect. Our trucks are 5 on 4.75" Pro Comp Wheels 152-5762 - Pro Comp Xtreme Rock Crawler Series 152 Black Wheels - Overview - SummitRacing.com I would urge you to read through various threads in the tire section and the lifting or suspension sections. It seems there are "what size tires can i fit" threads posted every few days and as you read, you will find plenty of additional information. |
Ok, thanks man I appreciate it!
Pro Comp Wheels Part 52-5762 - 52 Rock Crawler Series - Gloss Black Powder Wheels by Pro Comp would these work? sorry no need to reply, the specs of your suggested rim match this one... sorry actually a quick yes or no, then if I put 29-30in tires all would be ok?? |
