wheel adapter help
Has anyone tried putting on the 1.25" wheel adapters or have pictures of these on? Would this size wheel adapter be a big noticeable differance? All criticizm and advice welcome. Thanks in advanced.
What is a 1.25" wheel adapter?
Do you mean 1.25" wheel spacer? If so then yeah I have ran wheel spacers before. Nothing wrong with having them as long as you have long enough lug studs to compensate for the spacer...... Whether or not you notice the difference...... Yea Im sure youll notice it a little if you are lookin for it. |
r
instead of just going inbetween the hub and rim the wheel adapters bolt onto the hub or whatever and then they have new studs on the adapter and the wheel mounts onto that. Thats how you can convert to different lug patterns. Juts google it for pictures for best explanation
I know what a wheel adapter is for adapting lug patterns. Are you buying these for that purpose or just to space your wheels out farther? Why not just get wheels with less backspacing if the latter is the case?
o
ah I see I thought you didn't know, i'm putting some different lug pattern rims on and want them to have a wider stance but not sure if 1.25'' will make a differance
Yeah but it would be safer in the long run to just buy wheels to fit the truck. I know people who have broken these going down the hwy and had a wheel come off.
I didnt know what you meant by 1.25" wheel adapter. They are all gonna space the wheel out . I wouldve understood had you said 5 on 4.50 to 5 on 5 wheel adapter. Sorry |
wanting to do a 4.5 4x4 blazer to a 4.25 adapter
is it even possible? i bought the rims cause they told me that they will fit came off a caddy figured they would go to bolt it on and the studs all fit to it with a 1/4 in diff :/
| All times are GMT -5. The time now is 07:25 AM. |
